Image Preview, Group view, does not always
Posted: 08 Dec 2023, 01:52
Image Preview, Group view, does not always - view the group of thumbnails.
I believe this is a new issue with 4.5.56.
Image mode, Similar pictures, all groups expanded, 18 K groups, 41 K files
Previews enabled
sometimes as i move from ... group-file-file-group
sometimes when i hit that next group, sometimes,
it displays the previous group's -file- rather then the new groups thumbnails
what the exact trigger is, i haven't figured that out, yet, but the issue exists
i thought, maybe it was a focus issue, & with that, how do i "focus" without
using the cursor to move up or down - which i know would "fix" the issue?
with that, i simply & even though highlight was already there, single mouse-clicked
on the Group, & with that, the expected thumbs turned up
so maybe it is a "focus" issue?
so... ?
(drive is not, has not, gone to sleep, nothing otherwise affecting CPU/RAM
with AllDup or otherwise)
(i did not notice that behavior, particularly, in 4.5.54, though my number
of dups is significantly higher)
(in any case, none of this is a big deal, but it does exist)
various scenarios when this happened...
when this happens,
if i stay there, on the Group, things stay as is, unchanged, displaying an incorrect picture
if i move up to the previous file, or
if i move down to the next file
& then back up to the (what was erroneous) group,
it then displays that group's thumbnails as expected
<not quite sure what i just said is correct? maybe it is more like i'm in a
group, on a file, & i arrow-key down, quickly - though still single key presses,
such that i "kind of" skip over the next group & at that point, i'm on a 'file'
in the next group, & then if i "back up" to the group itself, i then show that
last file instead of the group thumbs ?>
group - down File - down File - UP - down File - down GROUP
- at that point, 'down GROUP' had File instead of thumbnails
arrow-key down, only a few, group-file-file-group, as it was, the 2nd file
happened to no longer be there, so (& i didn't really see it at that point)
but when i landed on the 2nd 'group', the "group" thumnail displayed:
"the file ...014_0014.jpg couldn't be displayed!
ERROR: FreeImage - FreeImage_LoadU: failed to open input file (Load error) |
GdipCreateBitmapFromFile: (2) Invalid Parameter"
now, all of that is fine & expected
- but it was not expected that that message displayed when i was on a Group
entry, not (any longer) on the file
^-that is just as it happened to happen, & i'm not saying that "error" played
into what happened, necessarily, it just happened to be what happened at the
time (& again, that the error existed was completely expected [as beforehand
i had renamed the file - outside of AllDup]
Previews enabled
so... ?
when this happens,
