I just upgraded to 4.5.10 and whilst the Info Column is great there is no way to refresh it if the information is incorrect
Given that what is on drive letters can change as USB drives are inserted/ejected having incorrect information is worse than not having it
AllDup 4.5.10 Info Column
Re: AllDup 4.5.10 Info Column
The field at the info column will be filled automatically only once when a drive letter is added.
You can edit/delete the info field anytime by a double-click.
