resort data in text files before comparison
Is it possible to have a format or sort step before the comparison runs so that it would take each file that you want to compare the contents on, then format/sort the file, and then compare the contents?
Re: resort data in text files before comparison
No, that's not possible.
While not directly, you could automate something.
(Pseudo-code)
Something like that would
sort each file (by default, alpha)
write the sorted file to \tmp\X\[filename]
when that is done
AllDup fires up & does a content comparison on the files in \tmp\X.
Now, once you've found the dups in \X\, you'd have to correlate them back to the source directory.
(Pseudo-code)
FOR I in *.txt
do
SORT %I > \tmp\X\%I
done
[path-to]\AllDup.exe -s4 \tmp\X\
when that is done
