find duplicate Video files by filename AND Audio Length
FinderDupLong
Post by FinderDupLong »
Hi, I love AllDup
but one option I cannot figure out:
I want to find all files in a folder ( and subfolders ) by a search method "Find duplicates on the basis of their properties" and then additionally by search method "Find video & audio files on the basis of the audio length"
So both filters have to be true.
I cannot find a possibility to "chain" this two filter kinds.
Re: find duplicate Video files by filename AND Audio Length
Sorry, that's not possible.
Everything 1.5 Alpha should be able to help.
Set your wanted directory; C:/MUSIC/Jethro Tull/, video or audio filter, audio:|video:, add the Length column.
C:/MUSIC/Jethro Tull <audio:|video:>
Right click a column, Add Columns -> (search on) length, add the 'Length Metadata' item.
With that, you now have a Length column that shows the audio/video length.
Right-click the Length column, 'Find Length Duplicates', will then sort the Length column by (duplicated) "lengths".
Method mentioned does not index that (length) data, but you can if you want.
All kinds of useful things Everything can do. Experiment & see if it can work for you.
