Multitasking, Multithreading, Simultaneous Task Execution
What happens if a few tasks are set to the same time via the scheduler? Can AllSync run multiple tasks simultaneously, or will the program always wait until one task ends before another begins? TIA
Re: Multitasking, Multithreading, Simultaneous Task Executio
Only one task can be started via the scheduler at the same time. Please use the "Tolerance" value of the tasks if you set the same start time to different tasks.
Simultaneously is not possible...vp wrote:I understand about the tolerance time, but I'd like to run more than one task simultaneously.
Yes, but the second task starts only if his start time + tolerance is higher than the time the first task is finished...My understanding is that if I have one task set to start at 2:00 and one at 2:01, the second will always begin after the first is done, and cannot run simultaneously. Is this correct?
Ooooh good hint...
The problem I see is that I would need to have a scheduler handy.... I like the way I sepcify maximum run times and make it quit at a certain hour, I really use that stuff. I prefer to wait until you implement it, rather than lose this wonderful functionality.
I also want to say what a great program! It is so smart, every angle seems to be covered, it's great because I feel that the author is on the same wavelength as me. The license model is brilliant, by the way. Look out for a purchase of 6 additional licenses in the next few days. Painful but brilliant :)
