How to improve duplicate file finder?
Euro skank
Post by Euro skank »
Hi,
Great free program, already deleted over a thousand tunes of my 220+ GBs music collection on first go using your recommended settings. Thanks so much!
However, I can't seem to find the right setting for weeding out some remaining duplicates. As you may see from the Winamp library screenshot below I still have several similar copies of the same songs:- eg. 3 x 'Zu Fuss Extrawelt 6.00 mins in duration. Any tips please?
Re: How to improve duplicate file finder?
What comparision criteria did you used to find thousand of music dups?
Euro skank
Hi,
Thanks for getting back to me. I think I used the following comparison criteria...
23/05/2020 12:00:56 - AllDup 4.4.28
23/05/2020 12:00:56 - Search Method: File name (SmartMatch: 90%)
23/05/2020 12:00:56 - 1.Source folder: C:\Users\euan7\Music
23/05/2020 12:00:56 - Option: Compare files from all source folders
23/05/2020 12:00:56 - Folder filter activated: 7
23/05/2020 12:00:56 - Filter type: Exclusive
23/05/2020 12:00:56 - 1.folder filter: c:\windows
23/05/2020 12:00:56 - 2.folder filter: c:\program files (x86)
23/05/2020 12:00:56 - 3.folder filter: c:\program files
23/05/2020 12:00:56 - 4.folder filter: ?:\system volume information
23/05/2020 12:00:56 - 5.folder filter: ?:\recycled
23/05/2020 12:00:56 - 6.folder filter: ?:\recycler
23/05/2020 12:00:56 - 7.folder filter: ?:\$recycle.bin
23/05/2020 12:00:56 - Determine file count of all source folders...
23/05/2020 12:00:57 - File count: 22,574
23/05/2020 12:00:57 - Scan: C:\Users\euan7\Music
23/05/2020 13:08:06 - Found 4,344 duplicates with a total of 44.75 GB inside folder 'C:\Users\euan7\Music'
23/05/2020 13:08:06 - Scanned files: 22,574
23/05/2020 13:08:06 - Groups: 2,022
23/05/2020 13:08:06 - File comparison count: 216,724,148
23/05/2020 13:08:06 - Duplicates: 4,344 (19%) (44.75 GB)
23/05/2020 13:08:06 - Elapsed time: 01:07:10
23/05/2020 13:12:58 - --------------------------------------------------
23/05/2020 13:12:58 - Action 'Move files to the Windows Recycle Bin' started.
23/05/2020 13:16:04 - Action 'Move files to the Windows Recycle Bin' complete.
23/05/2020 13:16:04 - Files moved to the Windows recycle bin: 2243 of 2243
23/05/2020 13:16:04 - Files removed from the search result: 2243
23/05/2020 13:19:47 - INFO: Unable to detect the VLC Media Player 32-bit version 3 on your system
Yet after deleting them there still seems to be quite a few dups (same duration with similar filename). Just wondering what you can recommend to filter out the remaining dups. Thanks.
You have to lower your match value or use another Algorithm to find more duplicates.
Euro skank
OK, I'll have a play around with the other algorithms.
Great program. I managed to get rid of a shit load of duplicates. Thanks again.
