Remove all groups with any files selected
I see AllDup can Remove all groups with all files selected. Can it Remove all groups with any files selected?
Re: Remove all groups with any files selected
any = some files selected at a group?
Yes, if one or more files are selected in a group.
Ok, i will add your suggestion to our ToDo-List:
"Remove all groups with some files selected"
I used the word "some" because this command will not remove groups with all files selected.
Correct?
Correct?
That's perfect! Thank you!
New update with the new remove command is available!
It works great! Thanks!
