Help Pointers Should Remain Active
"Help Pointers", the question marks, ?, Should Remain Active even if the associated selection field is not enabled.
(For instance, in the) Search Method [tab],
if 'File name' is not selected as a 'Comparison Criteria', the Help ? for the 'File Name' dialog does box not work.
It should, regardless.
Re: Help Pointers Should Remain Active
This will be fixed with the next update!
