Delete Zero Byte Files
I searched for duplicates by name and extension. The results contain many groups, some with large and small files, some with large and zero byte files. How can I select only the zero byte files in the groups?
Re: Delete Zero Byte Files
Try the action "Select all files except the smallest file". See main menu bar -> "Select".
With this example, the action "Select all files except the smallest file" would select File 2 and File 4. I'm looking for a way to select only File 4.
Group 1:
File 1 8 KB
File 2 2 KB
Group 2:
File 3 3 KB
File 4 0 KB
Currently you cant automatically select files by a specific size.
I will add this to the ToDo-List.
new update available:
Search Result / Menu 'Select': Added the command 'Select files by size' with the options 'smaller than', 'equal to' and 'larger than'.
