Run-time error '440'
I get an error when I click Search:
mtSplitter2
Automation error
Alldup 4.3.2 Portable on Windows 10
mtSplitter2
Automation error
Re: Run-time error '440'
1. Have you extracted all files form inside the file AllDupPortable.zip?
2. Please restart your computer and start AllDup again. Does this help?
The AllDup folder and executable works on a Windows 7 machine. Restarting the Windows 10 machine didn't help.
Please try out the AllDup installer setup with win10.
Which win10 version do you use?
Same problem with the installed version. I'm on Windows 10 1809 Enterprise.
Sorry, but we cant reproduce this problem with Win10 Pro v10.0.17134.590.
I guess the problem have something to do with the configuration of your windows system and/or the different software installations because we dont have any similar reports from other users.
(An earlier "440" thread, Win7 at that time, errors on start of all Dup.)
This old thread will not help the current user to fix this problem...
Can I download older versions to try and find one that works?
At our website you will find only the latest version to download but some other websites also hosting older versions: https://alldup.updatestar.com/
I can't download version 3 from that website and to be honest I'm also nervous about downloading stuff from unknown sites anyway. What do you think might be wrong with version 4? Do I have the wrong version of a runtime dependency?
Sorry, i dont know whats wrong with your win10 installation...
Please try out the latest beta version of AllDup: http://www.thummerer-software-design.de ... p_beta.php
With 4.3.12 (BETA) I get this error:
Microsoft Visual C++ Runtime Library
Runtime Error!
abnormal program termination
Runtime Error!
We have done another test with AllDup 4.3.12 Beta on a fresh installed Win10 Pro v1903 PC and everythings runs without any errors...
