'Select files by file name'
It would be nice if it could also respect the (Search:) setting, 'Search all visible columns'.
That way instead of only selecting by file name, you could select on (say) part of a directory path too.
RFE: Select files by file Path
Re: Select files by file name
Do you need something like 'Select files by file path'?
Re: Select files by file PATH
Sure, that would work too.
Hmm.
Wonder how "flat" path should be?
C:\DOC\PICS\T\Trains\
C:\DOC\PICS\T\Trampolines\
C:\DOC\PICS\TRACTORS\
*tra*, would find all.
*\tra*, would find all.
*pics\tra*, would find TRACTORS only.
Hmm.
