RFE: A Bit More Detail in Logs
Perhaps non-default filters, options, kind of thing.
Like Firefox's about:support has a "Important Modified Preferences" section.
19.11.2016 20:10:59 - Modifications: 'Compare only files within the same source folder'; '64bit file system redirection'
I see you do list filtered, but maybe expand on it?
11/19/2016 04:49:26 PM - Files filtered: 4
11/19/2016 04:49:26 PM - Files filtered: 4, Size & Text
Might help when you've enabled a setting you didn't realize, skewing your (expected) results.
Re: RFE: A Bit More Detail in Logs
It's done...
