Internet Access - Repeatedly
If a scan returns no results, the "Interet Hit" occurs - repeatedly - interfering with program operation.
At that point, you have to kill the program.
(Even if you can 'X' out of the program, it "returns".)
Create an empty directory, C:\TMP
Source Folders: C:\TMP
Search Method: File Content
Search Options: Exclude by size, smaller, 100 MB
Start Search
repeat:
Scripts are usually safe [heh, so says MS]. Do you want to allow scripts to run?
NO.
1 folders and 0 files were searched but no duplicates were found.
OK.
UI pops up (which is OK)
NO.
OK.
goto repeat:
Kill.
(In my case, I keep JavaScript disabled [well, at least set to prompt] in IE.)
Re: Internet Access - Repeatedly
Please install AllDup v4.02. Does this fix the problem?
Yes, 4.0.2 fixes it.
Thank you.
(I ran into this on WinXP.)
Thank you.
