Allsync stopped working
PDL_lab
Post by PDL_lab »
Hello,
since some days i have a problem with allsync. Always when i change some settings i get a message Allsync stopped working. I attached the message in the attachment.
The System is a Windows Server 2012 R2.
error 2.JPG (48.87 KiB) Viewed 10084 times
error 1.JPG (46.29 KiB) Viewed 10084 times
Re: Allsync stopped working
Please restart your windows server and try again.
Does this help?
PDL_lab
Post by PDL_lab »
I will give it a try.
Just it is not so easy to make a restart. Is there another way to restart the software from fresh?
I guess your windows server runs very long without a restart and now something is wrong with the memory management.
There is no other way to reset the memory management of windows...
PDL_lab
Post by PDL_lab »
In der tat, der Restart scheint das Problem behoben zu haben. Danke fuer die Hilfe
