RFE: Jump to next expanded group
Some sort of enhanced algorithm in the jump.
As it is now, the jump places the group at the bottom of the screen, with the first item in the group partially visible.
At that point, almost always, you're going to need to scroll down.
So, if at the least, you displayed the group & the first two (or one, fully, if only one existed ?) items in the group, it would save a lot of unnecessary (manual) movements.
(Jump to previous expanded group is unaffected, as it places the [previous] group at the top of the list & any items on the list are visible, below.
I suppose Jump to next could do the same?)
Re: RFE: Jump to next expanded group
Thx for the feedback.
With the next update the "next expanded group" will be showed at the top most row possible.
