Tip: Combine Folder Dialogs
Synetech
Post by Synetech »
Hi,
I just wanted to suggest that the various folder-selection dialogs can be combined:
Figure 1: The Select All Within Folder-Structure dialog has both a folder tree and a direct-enter edit field
Figure 2: The Add Folder dialog needs the direct-enter edit field
Figure 3: The Enter Text + Add Folder dialogs = Folders-Structure dialog (+ check-boxes)
(Also has an inaccurate window title.)
Figure 4: The Edit Folder dialog is identical to the Enter Text dialog; can be combined with Add Folder dialog to create a unified Add/Edit Folder dialog
Re: Tip: Combine Folder Dialogs
Thanks for your feedback!
Figure 1
I removed the unnecessary edit field and the checkbox.
Figure 2
The edit field is not available if you can select more than one folder via the checkboxes.
Figure 3
I fixed the window title at the Enter Text dialog.
Synetech
Post by Synetech »
Administrator wrote:Thanks for your feedback!
Figure 1
It’s not really unnecessary, it’s just a little redundant, but still convenient.
(I recently noticed a few new tricks and tweaks in the newer versions that are really nice, like the information in the scanning window. :D)
