RFE: Indicate when Context Search, Ignore ID3/Exif
When you do a Content search, ignoring ID3 tags or Exif metadata, it would be nice to have files that are the "same" except for the tag/metadata indicated in some fashion, differentiating them from files that are "truely" duplicate.
Just would be nice to know that the "dups" aren't true dups.
IOW it would prompt (me) to say hey, they're the "same", but lets just take a peak see just what makes them different.
Re: RFE: Indicate when Context Search, Ignore ID3/Exif
Thats not possible, because AllDup dont have this information when you ignore the ID3 tag or Exif metadata.
