multiple criteria select
everend
Post by everend »
Is there a way to use multiple types of criteria to select files? I have a search with 6600 files in 2445 groups. Some of the duplicates are the same file (different file names) in the same folder, some are same file in different folders. I'm going through each group, selecting the appropriate duplicate to remove, however going through this many groups will take time. It would cut the list down if I could "select the longer file name duplicate in groups where duplicate files are in the same folder" Please let me know if there is a way to do this using current functionality, without re-running the duplicate search.
thanks
Everend
Re: multiple criteria select
Sorry, "select the longer file name duplicate in groups where duplicate files are in the same folder" is not possible.
