Feature Request
britd
Feature Request
Post by britd »
The Remove options "Remove ***", etc. could be replaced with "Hide ****" and a new option to "Unhide hidden files" or "Show hidden files" should be added.
Thanks for for great application! Looking forward to the next update!
Re: Feature Request
Its easy to implement a function to hide files but all other functions dont care about this state. Example: If you hide 50% of the files and select the function "Select all files" AllDup will select all files (hidden or not)!
britd
Post by britd »
That sounds less useful and kinda dangerous. Is it too hard to make the other functions only act on the displayed files?
We have to change the source code everywhere and do many tests to verify everything. A very time consuming task...
