I have LOTS of duplicates, and I've run the scan and would like to delete all but the newest version of the dupes.
I'm just not sure - does the results list include the original file and the redundant file? If I select all and delete will I have deleted the originals too? I have about 500GB of duplicates showing on the report (which is possible... old data combined with new drives, etc.)
I hope I don't have to go through every file and choose one. Yikes!
Seems like a dumb question, but an important one!
Thanks
Do results show duplicates ONLY, or ALL files with same name
Re: Do results show duplicates ONLY, or ALL files with same
AllDup always shows ALL duplicates. How should AllDup know what duplicate file is the original?
Yes AllDup can't know what the "original" file is but I don't think andante147 actually meant. Depending on the search criteria, if only Name and Extension were selected all files wouldn't necessarily be identical which is what I think he he meant.Administrator wrote:AllDup always shows ALL duplicates. How should AllDup know what duplicate file is the original?
More importantly to answer his question.
The answer would be you will delete ALL files.andante147 wrote:If I select all and delete will I have deleted the originals too?
As far as;
Use the one of the selection criteria like "Select all file except the newest file" in the search results window to multiple files at once.andante147 wrote: I hope I don't have to go through every file and choose one. Yikes!
andante147, Whatever you do make sure you back it up. There are many useful option in AllDup's file deletion manager to save, move, and rename the files you have selected.
Does that clear things up?
