Error When Run from BartPE CD
donny
Post by donny »
I get this error when running AllDup from a BartPE CD:
run-time error -2147221020
automation error - invalid syntax
It runs OK if I copy the AllDup folder to the RAM disc and run it from the RAM disc.
Re: Error When Run from BartPE CD
AllDup needs to create files inside the alldup-portable-directory. That's the reason why you have to start AllDup with a ram drive.
donny
Post by donny »
Do you know why AllDup does not appear in the taskbar? If I switch to another application I have to minimize the other application to get back to AllDup because it isn't in the taskbar.
Sorry, i never see this problem before. Do you see the AllDup icon if you use the key combination ALT + TAB?
donny
Post by donny »
Yes.
I think its a windows problem if no other software hide Alldup from the taskbar...
