remove all folder context menu command gone in 3.3
FrizzleFry
Post by FrizzleFry »
It seems the command to remove all folders in the source folders context menu has been removed in the new version (3.3)... is this intentional?
NEW: Source Folder List / Context Menu: Added "Paste folders from clipboard".
NEW: Source Folder List / Context Menu: Added "Deselect all folders".
I do not see these commands either...
Re: remove all folder context menu command gone in 3.3
Please right-click on any blank area at the folder list to get the other context menu. We will move the menu actions "Remove/Deselect all folders" to the folder context menu with the next minor update.
FrizzleFry
ok, I see them. I thought I had tried right-clicking in the empty area but I guess I did not.
Thanks,
BTW, loading the log files is working great from both the main window and search results.
