Hi,
When you start a search, AllDup asks if you want to use the file and folder filters. Selecting Yes, causes both file and folder filters to be active, but selecting no only disables folder filters; file filters are still active and must be turned off in the main interface to not use them for a search (which means cancelling the current search).
File Filters Still Used Even When Selecting NO in Prompt
Re: File Filters Still Used Even When Selecting NO in Prompt
Thanks for the information. Drop me email if you need a new update with the problem fixed.
