Feature Request: Compare with External Application
corinthianclock
Post by corinthianclock »
I want to select two files and pass them to an external application for processing or comparison. The implementation would simply launch an application passing it the two selected files.
Re: Feature Request: Compare with External Application
We have note your suggestion to our ToDo-List for upcoming releases.
Your feature suggestion was added. Please send me a email if you want to test the new feature.
corinthianclock
This is fantastic! The setting is even saved in profiles, so if you had more than one application you can switch profiles. Thanks! This is the best dupe finder I've ever used!
donny
Post by donny »
I agree, this is the best dupe finder available! I love this new feature. Would the developer consider adding multiple compare applications? I have several that I want to use and prefer not to change profiles and rerun a compare each time to switch. Many thanks to the developer(s).
I have noted your suggestion to our ToDo-List. Thanks for the feedback!
