Find files NOT duplicated!
Hi,
I would like to be able to identify and manipulate files NOT duplicated (in this case not backed up). Does AllDup support this 'inverse' function? (I can't see how I can do this).
'Sync' or backup programs always assume source/destination folders are the same whereas this may not be the case so produce an erroneous 'missing' file report - dupe finders don't assume the same folder structure so suit my purpose.
Thanks, Jonny
Thanks, Jonny
Re: Find files NOT duplicated!
Sorry, thats not possible with AllDup.
A new feature for the next release?
I will note your suggestion to our ToDo-List!
Cool. Thx - certainly a useful feature I think.
Hi, finding not duplicates will be a very useful feature!Administrator wrote:I will note your suggestion to our ToDo-List!
I have 2 PC with nearly the same files but organized in a different directory structure.
I would like to know if there is some file not present in one of the PCs.
It's is impossible to find with a classic sync tool, because they use paths.
It's is impossible to find with a classic dup finder tool, because they look for duplicates.
So i hope this missing feature in AllDup will be implemented.
Thanks a lot.
Daniele
NEW FEATURE: Find files that aren't duplicates
Find files that aren't duplicates when comparing the contents of two directories would be a great new feature. I need this. The software author could add it as a paid version feature or not.
Great program, my compliments to the chef !
find NOT duplicated
Let me add a plea for this feature.
does your AllSync do it?
Re: find NOT duplicated
No, AllSync dont search for duplicate or non duplicate files.quicktime wrote:does your AllSync do it?
Come on guys, back in Sep 2010 you said 'I will note your suggestion to our ToDo-List!'.
This feature would separate you from the competition... I'm still waiting
Sorry, we have no time at this moment to implement this feature...
