I would like to remove files in a folder that all have a common text string within the file name. the text string 'thumbnail' is common to all files that I want to delete
Example:
I have played with all manor of *thumbnail.* combinations but I cannot make it work. What should I do?
Removing files with common file name element
Re: Removing files with common file name element
You only need a inclusive file filter with the text:
*thumbnail*
Also make sure the option "Ignore wildcards..." is deactivated.
*thumbnail*
