Email option when using a scheduled backup
mtn_roadie
Post by mtn_roadie »
win2k server
Allsync 2.2.18 business edition
I've tried to set up Allsync to email me when a backup routine is complete. In the scheduler's option I have checked the appropriate options and have successfully sent several test emails. However, when I log off the system and let the service take over, the email is not sent (though the backup runs fine).
Here is the log file for the session:
1/13/2005 5:20:00 PM - ==================================================
1/13/2005 5:20:00 PM - Copy operation started
1/13/2005 5:20:00 PM - PROFILE: two
1/13/2005 5:20:00 PM - COPY MODE: 1:1 copy
1/13/2005 5:20:00 PM - --------------------------------------------------
1/13/2005 5:20:00 PM - SOURCE: C:\www\xroubaix\clients\_ftp\
1/13/2005 5:20:00 PM - DESTINATION: \\206.162.224.28\Kindler Backup\test\
1/13/2005 5:20:00 PM - Processing: source --> destination
1/13/2005 5:20:01 PM - --------------------------------------------------
1/13/2005 5:20:01 PM - PROFILE-STATISTIC:
1/13/2005 5:20:01 PM - Elapsed time: 0:00:01
1/13/2005 5:20:01 PM - No changes were made during the copy operation.
1/13/2005 5:20:01 PM - ERROR: Winsock1_DataArrival: 40006 - Wrong protocol or connection state for the requested transaction or request
1/13/2005 5:20:11 PM - ERROR: SMTP: An error has occurred: The mail server is not responding. (Pos=)
1/13/2005 5:20:11 PM - Copy operation complete.
1/13/2005 5:20:11 PM - INFO: 1 of 1 license(s) have been used since starting AllSync.
1/13/2005 5:21:19 PM - AllSync Scheduler 2.2.18 - Business Edition launched.
1/13/2005 5:29:41 PM - AllSync Scheduler 2.2.18 shut down.
I'm not sure why there is a Winsock error when the test emails are successfully sent. I've tried several different combinations in the email configuration to no avail. Any suggestions.
::kindler chase::
Re: Email option when using a scheduled backup
sorry, but i cant reproduce this error if i logged off and the scheduler service is started. (tested with WinXP and installed the service with the administrator account)
if u start your profile with the scheduler (as a normal application) and u dont run into any errors with sending emails or something else, then the only problem is that the account u use for the scheduler service havent enough system-rights to use winsock or something else thats nessesary for sending emails.
does the scheduler service send emails if u are logged into your account?
mtn_roadie
The account I'm using for the service has full administrator access.
I tested the scheduler and ran the test profile while logged into the account. The profile runs, but the email is not sent - the same error shows up:
1/13/2005 6:53:03 PM - ==================================================
1/13/2005 6:53:03 PM - Copy operation started
1/13/2005 6:53:03 PM - PROFILE: two
1/13/2005 6:53:03 PM - COPY MODE: 1:1 copy
1/13/2005 6:53:03 PM - --------------------------------------------------
1/13/2005 6:53:03 PM - SOURCE: C:\www\xroubaix\clients\_ftp\
1/13/2005 6:53:05 PM - DESTINATION: \\206.162.224.28\Kindler Backup\test\
1/13/2005 6:53:05 PM - Processing: source --> destination
1/13/2005 6:53:06 PM - --------------------------------------------------
1/13/2005 6:53:06 PM - PROFILE-STATISTIC:
1/13/2005 6:53:06 PM - Elapsed time: 0:00:03
1/13/2005 6:53:06 PM - No changes were made during the copy operation.
1/13/2005 6:53:06 PM - ERROR: Winsock1_DataArrival: 40006 - Wrong protocol or connection state for the requested transaction or request
1/13/2005 6:53:16 PM - ERROR: SMTP: An error has occurred: The mail server is not responding. (Pos=)
1/13/2005 6:53:16 PM - Copy operation complete.
1/13/2005 6:53:16 PM - INFO: 1 of 1 license(s) have been used since starting AllSync.
I found this article on the MS support site:
http://support.microsoft.com/kb/183987/EN-US/
Also, whenever I run a test email, two (2) duplicate emails are being sent instead of one (1). This happens any time I test the emailer.
::kindler chase::
what happend if u run the profile with the scheduler as a normal application? does sending emails works?
thats not the problem, i've checked the source code for that.
i've checked the test email again with AllSync 2.2.19, but i only recieve one test email.
i think the problem is the email server u use for sending emails. can u try a other email server for testing?
mtn_roadie
I'm not sure if I understand what you're asking, but the same error occurs under these scenarios:
1. open scheduler and run the test profile manually (I am logged on as a user).
or
2. scheduler runs under the service (I am not logged in as a user).
or
3. the service is disabled and the scheduler is turned on while I'm logged on as a user (same as 1, except the service is turned off).
I've never had a problem with the mail server; unfortunately, it's the only mail server I have access to as well.
Oddly enough, I can not 100% of the time duplicate the 2 emails being sent out. Sometimes it is one, other times it is two.
I just received an email report from my Allsync detailing an error - though I'm not sure where I configured the application to send me an error report, nor why it sends me an error report, but not the copy report. Here's the error I just received:
Time: 1/13/2005 9:02:30 PM
Prog: AllSync 2.2.18
Modul: frmTimer
Function: ProfillisteLaden
Line: 430
Error: 9 - Subscript out of range
Path: C:\Program Files\AllSync\AllSync.exe
OS: Windows 2000 (Service Pack 4) Version: 5.0 Build: 2195 ID: 2
IE: 6.0.2800
Mem: 9.78 MB free, 255.55 MB used
CPU: (1) Pentium 586.6.2051 [Intel Pentium Pro, II, III or 4] Model 8, Stepping 3, 700 MHz
Screen: 1024x768
Debug0: c:\program files\allsync\profile\test\network_test.pas
Stack: 2600075B59110C4F3B574C1D060E114D510E11
App: AllSync Scheduler Service 2.2.18 - Business Edition
Data: C:\Program Files\AllSync
SM: 2
P:
KM: 0
KV: 0
Ed: 3
La: 9
Can you provide a screen shot of how you've configured your scheduler's email server settings? Or provide some suggestions/examples of what would be entered into the email setting's fields?
As I've previously mentioned, the test email is sent every time; even under several different configurations in the email settings option.
::kindler chase::
but u can send test emails via the scheduler options?
i have reproduced and fixed the bug with the duplicate emails. check the update to allsync version 2.2.20
this error is also fixed with the new update. you recieved this bugreport, because u have activated the email option "Send bug report automatically to the following addresses:"
please send me your file "allsync.ini" to "support (at) allsync (dot) de" and i check your settings of the email server. maybe i can reproduce the problem.
mtn_roadie
Yes, 100% of the time.
OK - I just thought it was odd that I'd receive this email, but not the report emails.
Sure - I've sent it to the support email address.
OK - here's an odd one. The service ran a scheduled profile last night. 4 profiles are chained together - I recieved confirmation emails on the 2nd and 3rd profile, but the 1st and 4th (last) profile produced the winsock error. Here's the log:
1/14/2005 4:20:01 AM - ==================================================
1/14/2005 4:20:01 AM - Copy operation started
1/14/2005 4:20:01 AM - PROFILE: _My Docs
1/14/2005 4:20:01 AM - COPY MODE: 1:1 copy
1/14/2005 4:20:01 AM - --------------------------------------------------
1/14/2005 4:20:01 AM - SOURCE: C:\Documents and Settings\kindler\My Documents\
1/14/2005 4:20:02 AM - DESTINATION: \\206.162.224.28\Kindler Backup\BackUps\alpha\Documents and Settings\kindler\My Documents\
1/14/2005 4:20:02 AM - Processing: source --> destination
1/14/2005 7:34:38 AM - --------------------------------------------------
1/14/2005 7:34:39 AM - SOURCE: C:\Documents and Settings\kindler\Application Data\AllSync\
1/14/2005 7:34:39 AM - DESTINATION: \\206.162.224.28\Kindler Backup\BackUps\alpha\Documents and Settings\kindler\Application Data\AllSync\
1/14/2005 7:34:39 AM - Processing: source --> destination
1/14/2005 7:34:39 AM - --------------------------------------------------
1/14/2005 7:34:39 AM - SOURCE: C:\Program Files\AllSync\profile\
1/14/2005 7:34:39 AM - DESTINATION: \\206.162.224.28\Kindler Backup\BackUps\alpha\Program Files\AllSync\profile\
1/14/2005 7:34:40 AM - ERROR: The file 'C:\Program Files\AllSync\profile\Essentials - alpha\_my docs.log' couldn't be opened.
1/14/2005 7:34:42 AM - --------------------------------------------------
1/14/2005 7:34:42 AM - PROFILE-STATISTIC:
1/14/2005 7:34:42 AM - Elapsed time: 3:14:41
1/14/2005 7:34:42 AM - Files copied: 17
1/14/2005 7:34:42 AM - Files created: 105
1/14/2005 7:34:42 AM - Files deleted: 4
1/14/2005 7:34:42 AM - Folders created: 20
1/14/2005 7:34:42 AM - Data volume copied into the destination folders: 624,149.01 KB
1/14/2005 7:34:42 AM - ERROR: Winsock1_DataArrival: 40006 - Wrong protocol or connection state for the requested transaction or request
1/14/2005 7:34:52 AM - ERROR: SMTP: An error has occurred: The mail server is not responding. (Pos=)
1/14/2005 7:34:52 AM - PROFILE: www
1/14/2005 7:34:52 AM - COPY MODE: 1:1 copy
1/14/2005 7:34:52 AM - --------------------------------------------------
1/14/2005 7:34:52 AM - SOURCE: C:\www\
1/14/2005 7:34:52 AM - DESTINATION: \\206.162.224.28\Kindler Backup\BackUps\alpha\www\
1/14/2005 7:34:52 AM - Processing: source --> destination
1/14/2005 7:55:58 AM - ERROR: The file 'C:\www\xroubaix\nntpfile\group.lst' couldn't be opened.
1/14/2005 7:55:58 AM - ERROR: The file 'C:\www\xroubaix\nntpfile\groupvar.lst' couldn't be opened.
1/14/2005 7:56:31 AM - --------------------------------------------------
1/14/2005 7:56:31 AM - PROFILE-STATISTIC:
1/14/2005 7:56:31 AM - Elapsed time: 0:21:39
1/14/2005 7:56:31 AM - Files copied: 486
1/14/2005 7:56:31 AM - Files created: 333
1/14/2005 7:56:31 AM - Files deleted: 60
1/14/2005 7:56:31 AM - Folders created: 17
1/14/2005 7:56:31 AM - Folders deleted: 1
1/14/2005 7:56:31 AM - Data volume copied into the destination folders: 55,718.85 KB
1/14/2005 7:56:37 AM - SMTP: Email has been sent.
1/14/2005 7:56:37 AM - PROFILE: Mdaemon
1/14/2005 7:56:37 AM - COPY MODE: 1:1 copy
1/14/2005 7:56:37 AM - --------------------------------------------------
1/14/2005 7:56:37 AM - SOURCE: C:\MDaemon\
1/14/2005 7:56:37 AM - DESTINATION: \\206.162.224.28\Kindler Backup\BackUps\alpha\MDaemon\
1/14/2005 7:56:37 AM - Processing: source --> destination
1/14/2005 7:57:22 AM - ERROR: The file 'C:\MDaemon\Logs\http.log' couldn't be opened.
1/14/2005 7:57:22 AM - ERROR: The file 'C:\MDaemon\Logs\InstantMessaging.log' couldn't be opened.
1/14/2005 7:57:27 AM - ERROR: The file 'C:\MDaemon\Logs\MDaemon-all.log' couldn't be opened.
1/14/2005 7:57:46 AM - ERROR: The file 'C:\MDaemon\Logs\MDaemon-AntiSpam.log' couldn't be opened.
1/14/2005 7:58:07 AM - ERROR: The file 'C:\MDaemon\Logs\MDaemon-AntiVirus.log' couldn't be opened.
1/14/2005 7:58:30 AM - ERROR: The file 'C:\MDaemon\Logs\MDaemon-Content-Filter.log' couldn't be opened.
1/14/2005 7:58:48 AM - ERROR: The file 'C:\MDaemon\Logs\MDaemon-DomainPOP.log' couldn't be opened.
1/14/2005 7:58:51 AM - ERROR: The file 'C:\MDaemon\Logs\MDaemon-IMAP.log' couldn't be opened.
1/14/2005 7:58:51 AM - ERROR: The file 'C:\MDaemon\Logs\MDaemon-MDConfig.log' couldn't be opened.
1/14/2005 7:58:52 AM - ERROR: The file 'C:\MDaemon\Logs\MDaemon-MultiPOP.log' couldn't be opened.
1/14/2005 7:58:53 AM - ERROR: The file 'C:\MDaemon\Logs\MDaemon-POP.log' couldn't be opened.
1/14/2005 7:59:17 AM - ERROR: The file 'C:\MDaemon\Logs\MDaemon-RAW.log' couldn't be opened.
1/14/2005 7:59:20 AM - ERROR: The file 'C:\MDaemon\Logs\MDaemon-Routing.log' couldn't be opened.
1/14/2005 7:59:42 AM - ERROR: The file 'C:\MDaemon\Logs\MDaemon-SMTP-(in).log' couldn't be opened.
1/14/2005 8:00:03 AM - ERROR: The file 'C:\MDaemon\Logs\MDaemon-SMTP-(out).log' couldn't be opened.
1/14/2005 8:00:25 AM - ERROR: The file 'C:\MDaemon\Logs\MDaemon-Spam-Blocker.log' couldn't be opened.
1/14/2005 8:00:31 AM - ERROR: The file 'C:\MDaemon\Logs\MDaemon-System.log' couldn't be opened.
1/14/2005 8:00:32 AM - ERROR: The file 'C:\MDaemon\Logs\WDaemon.log' couldn't be opened.
1/14/2005 8:00:56 AM - ERROR: The file 'C:\MDaemon\Logs\WorldClient.log' couldn't be opened.
1/14/2005 8:06:24 AM - --------------------------------------------------
1/14/2005 8:06:24 AM - PROFILE-STATISTIC:
1/14/2005 8:06:24 AM - Elapsed time: 0:09:47
1/14/2005 8:06:24 AM - Files copied: 166
1/14/2005 8:06:24 AM - Files created: 346
1/14/2005 8:06:24 AM - Files deleted: 386
1/14/2005 8:06:24 AM - Folders deleted: 19
1/14/2005 8:06:24 AM - Data volume copied into the destination folders: 33,628.52 KB
1/14/2005 8:06:30 AM - SMTP: Email has been sent.
1/14/2005 8:06:30 AM - PROFILE: nntp
1/14/2005 8:06:30 AM - COPY MODE: 1:1 copy
1/14/2005 8:06:30 AM - --------------------------------------------------
1/14/2005 8:06:30 AM - SOURCE: C:\nntp\
1/14/2005 8:06:30 AM - DESTINATION: \\206.162.224.28\Kindler Backup\BackUps\alpha\nntp\
1/14/2005 8:06:30 AM - Processing: source --> destination
1/14/2005 8:06:48 AM - ERROR: The file 'C:\nntp\ncubed\article.hsh' couldn't be opened.
1/14/2005 8:06:48 AM - ERROR: The file 'C:\nntp\ncubed\group.lst' couldn't be opened.
1/14/2005 8:06:48 AM - ERROR: The file 'C:\nntp\ncubed\groupvar.lst' couldn't be opened.
1/14/2005 8:07:06 AM - ERROR: The file 'C:\nntp\ncubed\history.hsh' couldn't be opened.
1/14/2005 8:08:28 AM - ERROR: The file 'C:\nntp\ncubed\news content\support\0.xix' couldn't be opened.
1/14/2005 8:08:48 AM - ERROR: The file 'C:\nntp\ncubed\xover.hsh' couldn't be opened.
1/14/2005 8:09:06 AM - ERROR: The file 'C:\nntp\nCubed Beta\article.hsh' couldn't be opened.
1/14/2005 8:09:06 AM - ERROR: The file 'C:\nntp\nCubed Beta\group.lst' couldn't be opened.
1/14/2005 8:09:06 AM - ERROR: The file 'C:\nntp\nCubed Beta\groupvar.lst' couldn't be opened.
1/14/2005 8:09:26 AM - ERROR: The file 'C:\nntp\nCubed Beta\xover.hsh' couldn't be opened.
1/14/2005 8:09:44 AM - ERROR: The file 'C:\nntp\webdevbiz\article.hsh' couldn't be opened.
1/14/2005 8:09:44 AM - ERROR: The file 'C:\nntp\webdevbiz\group.lst' couldn't be opened.
1/14/2005 8:09:44 AM - ERROR: The file 'C:\nntp\webdevbiz\groupvar.lst' couldn't be opened.
1/14/2005 8:10:03 AM - ERROR: The file 'C:\nntp\webdevbiz\history.hsh' couldn't be opened.
1/14/2005 8:10:23 AM - ERROR: The file 'C:\nntp\webdevbiz\news content\public\803a0000.xix' couldn't be opened.
1/14/2005 8:10:24 AM - ERROR: The file 'C:\nntp\webdevbiz\news content\public\873a0000.nws' couldn't be opened.
1/14/2005 8:10:24 AM - ERROR: The file 'C:\nntp\webdevbiz\news content\public\8a3a0000.nws' couldn't be opened.
1/14/2005 8:10:25 AM - ERROR: The file 'C:\nntp\webdevbiz\news content\public\923a0000.nws' couldn't be opened.
1/14/2005 8:10:30 AM - ERROR: The file 'C:\nntp\webdevbiz\news content\public\b73a0000.nws' couldn't be opened.
1/14/2005 8:10:31 AM - ERROR: The file 'C:\nntp\webdevbiz\news content\public\b83a0000.nws' couldn't be opened.
1/14/2005 8:10:31 AM - ERROR: The file 'C:\nntp\webdevbiz\news content\public\b93a0000.nws' couldn't be opened.
1/14/2005 8:10:31 AM - ERROR: The file 'C:\nntp\webdevbiz\news content\public\ba3a0000.nws' couldn't be opened.
1/14/2005 8:10:31 AM - ERROR: The file 'C:\nntp\webdevbiz\news content\public\bb3a0000.nws' couldn't be opened.
1/14/2005 8:10:31 AM - ERROR: The file 'C:\nntp\webdevbiz\news content\public\bc3a0000.nws' couldn't be opened.
1/14/2005 8:10:31 AM - ERROR: The file 'C:\nntp\webdevbiz\news content\public\bd3a0000.nws' couldn't be opened.
1/14/2005 8:10:31 AM - ERROR: The file 'C:\nntp\webdevbiz\news content\public\be3a0000.nws' couldn't be opened.
1/14/2005 8:10:31 AM - ERROR: The file 'C:\nntp\webdevbiz\news content\public\c03a0000.nws' couldn't be opened.
1/14/2005 8:10:58 AM - ERROR: The file 'C:\nntp\webdevbiz\xover.hsh' couldn't be opened.
1/14/2005 8:11:17 AM - ERROR: The file 'C:\nntp\webdevbiz backroom\article.hsh' couldn't be opened.
1/14/2005 8:11:17 AM - ERROR: The file 'C:\nntp\webdevbiz backroom\group.lst' couldn't be opened.
1/14/2005 8:11:17 AM - ERROR: The file 'C:\nntp\webdevbiz backroom\groupvar.lst' couldn't be opened.
1/14/2005 8:11:49 AM - ERROR: The file 'C:\nntp\webdevbiz backroom\xover.hsh' couldn't be opened.
1/14/2005 8:11:49 AM - --------------------------------------------------
1/14/2005 8:11:49 AM - PROFILE-STATISTIC:
1/14/2005 8:11:49 AM - Elapsed time: 0:05:19
1/14/2005 8:11:49 AM - Files copied: 27
1/14/2005 8:11:49 AM - Files created: 612
1/14/2005 8:11:49 AM - Files deleted: 249
1/14/2005 8:11:49 AM - Data volume copied into the destination folders: 21,802.36 KB
1/14/2005 8:11:49 AM - ERROR: Winsock1_DataArrival: 40006 - Wrong protocol or connection state for the requested transaction or request
1/14/2005 8:11:59 AM - ERROR: SMTP: An error has occurred: The mail server is not responding. (Pos=)
1/14/2005 8:11:59 AM - Copy operation complete.
1/14/2005 8:11:59 AM - INFO: 1 of 1 license(s) have been used since starting AllSync.
::kindler chase::
mtn_roadie
For reference, here are the logs for each of the 4 emails that were sent during the backup operation in the previous post (all email addresses have been removed):
Log for 1/14/2005 7:34:42 AM - ERROR: Winsock1_DataArrival: 40006
Fri 2005-01-14 07:34:42: [568:208:1] Accepting SMTP connection from [127.0.0.1 : 2217]
Fri 2005-01-14 07:34:42: [568:208:1] --> 220 xroubaix.com ESMTP MDaemon 6.8.5; Fri, 14 Jan 2005 07:34:42 -0500
Fri 2005-01-14 07:34:52: [568:208:1] Socket connection closed by the other side (how rude!)
Fri 2005-01-14 07:34:52: [568:208:1] SMTP session abnormally terminated, 0 bytes transferred.
Log for 1/14/2005 7:56:37 AM - SMTP: Email has been sent.
Fri 2005-01-14 07:56:32: [544:210:1] Accepting SMTP connection from [127.0.0.1 : 2237]
Fri 2005-01-14 07:56:32: [544:210:1] --> 220 xroubaix.com ESMTP MDaemon 6.8.5; Fri, 14 Jan 2005 07:56:32 -0500
Fri 2005-01-14 07:56:33: [544:210:1] <-- HELO AllSync
Fri 2005-01-14 07:56:33: [544:210:1] --> 250 xroubaix.com Hello AllSync, pleased to meet you
Fri 2005-01-14 07:56:33: [544:210:1] <-- MAIL FROM: <EMAIL REMOVED>
Fri 2005-01-14 07:56:33: [544:210:1] --> 250 <EMAIL REMOVED>, Sender ok
Fri 2005-01-14 07:56:34: [544:210:1] <-- RCPT TO: <EMAIL REMOVED>
Fri 2005-01-14 07:56:34: [544:210:1] EMAIL REMOVED is an alias for EMAIL REMOVED
Fri 2005-01-14 07:56:34: [544:210:1] --> 250 <EMAIL REMOVED>, Recipient ok
Fri 2005-01-14 07:56:35: [544:210:1] <-- DATA
Fri 2005-01-14 07:56:35: [544:210:1] --> 354 Enter mail, end with <CRLF>.<CRLF>
Fri 2005-01-14 07:56:35: [544:210:1] Passing message through the spam filter...
Fri 2005-01-14 07:56:36: [544:210:1] Spam filter score/req: 0.10/10.0
Fri 2005-01-14 07:56:36: [544:210:1] --> 250 Ok, message saved <Message-ID: none present in original message>
Fri 2005-01-14 07:56:37: [544:210:1] <-- QUIT
Fri 2005-01-14 07:56:37: [544:210:1] --> 221 See ya in cyberspace
Fri 2005-01-14 07:56:37: [544:210:1] SMTP session successful, 1311 bytes transferred.
Fri 2005-01-14 07:56:37: [544:210:1] Shuffling message(s) into proper queue(s)
Fri 2005-01-14 07:56:37: [544:210:1] Message received from AllSync [127.0.0.1] <EMAIL REMOVED> with SMTP for <EMAIL REMOVED> [Size 1395] {c:\mdaemon\localq\md50000048290.msg}
Log for 1/14/2005 8:06:30 AM - SMTP: Email has been sent.
Fri 2005-01-14 08:06:25: [528:212:1] Accepting SMTP connection from [127.0.0.1 : 2245]
Fri 2005-01-14 08:06:25: [528:212:1] --> 220 xroubaix.com ESMTP MDaemon 6.8.5; Fri, 14 Jan 2005 08:06:25 -0500
Fri 2005-01-14 08:06:26: [528:212:1] <-- HELO AllSync
Fri 2005-01-14 08:06:26: [528:212:1] --> 250 xroubaix.com Hello AllSync, pleased to meet you
Fri 2005-01-14 08:06:26: [528:212:1] <-- MAIL FROM: <EMAIL REMOVED>
Fri 2005-01-14 08:06:26: [528:212:1] --> 250 <EMAIL REMOVED>, Sender ok
Fri 2005-01-14 08:06:27: [528:212:1] <-- RCPT TO: <EMAIL REMOVED>
Fri 2005-01-14 08:06:27: [528:212:1] EMAIL REMOVED is an alias for EMAIL REMOVED
Fri 2005-01-14 08:06:27: [528:212:1] --> 250 <EMAIL REMOVED>, Recipient ok
Fri 2005-01-14 08:06:28: [528:212:1] <-- DATA
Fri 2005-01-14 08:06:28: [528:212:1] --> 354 Enter mail, end with <CRLF>.<CRLF>
Fri 2005-01-14 08:06:28: [528:212:1] Passing message through the spam filter...
Fri 2005-01-14 08:06:29: [528:212:1] Spam filter score/req: 1.00/10.0
Fri 2005-01-14 08:06:29: [528:212:1] --> 250 Ok, message saved <Message-ID: none present in original message>
Fri 2005-01-14 08:06:30: [528:212:1] <-- QUIT
Fri 2005-01-14 08:06:30: [528:212:1] --> 221 See ya in cyberspace
Fri 2005-01-14 08:06:30: [528:212:1] SMTP session successful, 2936 bytes transferred.
Fri 2005-01-14 08:06:30: [528:212:1] Shuffling message(s) into proper queue(s)
Fri 2005-01-14 08:06:30: [528:212:1] Message received from AllSync [127.0.0.1] <EMAIL REMOVED> with SMTP for <EMAIL REMOVED> [Size 3020] {c:\mdaemon\localq\md50000048291.msg}
Log for 1/14/2005 8:11:49 AM - ERROR: Winsock1_DataArrival: 40006
Fri 2005-01-14 08:11:49: [568:216:1] Accepting SMTP connection from [127.0.0.1 : 2262]
Fri 2005-01-14 08:11:49: [568:216:1] --> 220 xroubaix.com ESMTP MDaemon 6.8.5; Fri, 14 Jan 2005 08:11:49 -0500
Fri 2005-01-14 08:11:59: [568:216:1] Socket connection closed by the other side (how rude!)
Fri 2005-01-14 08:11:59: [568:216:1] SMTP session abnormally terminated, 0 bytes transferred.
::kindler chase::
there must be a problem with the network connection if the email cant be send everytime, or?
mtn_roadie
Administrator wrote:there must be a problem with the network connection if the email cant be send everytime, or?
Good question. From the mail logs, it looks as if Allsync is closing down the socket/connection prematurely. I've not had any problems with the mail server in the past; it deals with thousands of emails a day. The mail server (Mdaemon) is located on the save server that Allsync is located, so there can not be a network connection problem.
I don't understand why it can successfully email some of the time and receive errors other times - especially during one operation such as a chained profile.
::kindler chase::
maybe the problem is that the emailserver and allsync use winsock at the same time?
mtn_roadie
Administrator wrote:maybe the problem is that the emailserver and allsync use winsock at the same time?
I really wouldn't know - this isn't my forte in the least. I just need to find out how to have the emails reliably sent. I'd hate to see this as an uresolved support request.
::kindler chase::
sorry, but u have to install and test allsync on a other computer to get the answer for the winsock problem.
mtn_roadie
Administrator wrote:sorry, but u have to install and test allsync on a other computer to get the answer for the winsock problem.
Hi Michael,
I'm sorry, but I do not have another server to test with. This is an error that needs to be resolved using the resources on hand.
Something just doesn't seem right if the test emails are always sent, but the live emails are sent only some of the time.
::kindler chase::
can u create a test account for me at your email server? if yes, please send me the nessesary informations via email and i do some tests here.
