Allsync 2.7.46 Business Edition
Backup local files on hard drive to network connected hard drive.
Copy Mode: Backup (7 generations / transfer old items to new backup)
Copy Method C
- 300000 data bytes
- no pause
Copy attempts for files:
- no: 1 / Interval: 5 sec's
- advanced rule: 112,1,1,1
Compare contents of files after copying (selected)
I'm receiving errors often enough every day on several files and type (i.e. jpg, txt, zip, js) during the nightly back up to be a bit concerned.
When I do a file comparison, here is the result which shows the error:1/9/2007 7:55:44 AM - ERROR: The content of files 'C:\<snip>\lang\en.js' and 'X:\<snip>\lang\en.js' is not identical.
Original:
lang["DlgCellWordWrap"] = "Word Wrap" ;
lang["DlgCellWordWrapNotSet"] = "<Not set>" ;
lang["DlgCellWordWrapYes"] = "Yes" ;
lang["DlgCellWordWrapNo"] = "No" ;
lang["DlgCellHorAlign"] = "Horizontal Alignment" ;
Backup:
la\
For reference, here is a sample of the visual file comparison that shows the error in the above example:
Any ideas what may be causing these errors?
