I'm trying to eliminate duplicate picture files within my entire %USERPROFILE%\Pictures tree structure. I have LOTS of subfolders to that main folder, and I know I have duplicates across the subfolders. Many levels of subfolder, as well, unfortunately.
I've tried every "Comparison method," and I keep coming up with duplicates listed that are identical - meaning THE SAME FILE in the SAME SUBFOLDER is listed twice within a group.
What do I need to use to search out duplicates within an entire folder tree?
Which search option to use?
Re: Which search option to use?
We never seen any search result with a file listed twice in a group.Cara wrote: 18 Nov 2026, 08:12 meaning THE SAME FILE in the SAME SUBFOLDER is listed twice within a group.
Are all files of the %USERPROFILE%\Pictures tree structure local files?
Please post a screenshot of this group with the column 'path' visible to check this issue.
Did you look in the particular directory itself (Windows Explorer or whatever)?picture files
Are there 2 of the "same" files there?
If there are, are you able to open both, separately, in your picture viewer?
In could be 2 similarly named files, that look alike, perhaps one using some unicode characters, & one not.
More fun with Unicode in file names
Here's relevant screenshots showing my selected AllDup options, the results, and the File Explorer view of the folder. Please note that this is NOT the only file that is included twice in the results, I just didn't want to show more. Also note that the desire, here, is to search the ENTIRE folder tree under PICTURES and compare all there to files found in C:\Users\M\Pictures\FromIphone_Organize.
I'm not able to include the images, so here's a link: https://imgur.com/a/DyQzH8A
After checking your screenshots i found your probem:
you search 2 source folders and the 1. source folder includes the 2. folder!
I thought I replied to this, already, but don't see it - so forgive any duplication.Administrator wrote: 19 Nov 2026, 19:17 After checking your screenshots i found your probem:
That is exactly what I WANT to do. I want to see if ANY folders under the 1. source folder contain duplicates of the files found in 2. folder.
What is the correct way to do this search? I could choose just the 1. source folder and the option "Compare only files within the same source and sub folder" - is that what I need, and then just ignore all the subfolders that are NOT my 2. folder?
you could work with a folder filter but i guess this would effect both source folders.I want to see if ANY folders under the 1. source folder contain duplicates of the files found in 2. folder.
afaik thats not possible.
