Cannot use command select all files that are located in selected folder
After updating Alldup to version 4.6.72 i can no longer use vital option to select all files that are located in selected folder and subfolders but after reverting to 4.5.56 i can use this option.I don't know what causes this on newer version and i am using windows 10.Also i would like to be able to change color of status bar from purple to another color.
Re: Cannot use command select all files that are located in selected folder
Cant reproduce this here. What's the exact name of the select command you are using?miki8823 wrote: 08 Jan 2026, 07:55 After updating Alldup to version 4.6.72 i can no longer use vital option to select all files that are located in selected folder and subfolders but after reverting to 4.5.56 i can use this option
Change the toolbar design at the options.miki8823 wrote: 08 Jan 2026, 07:55Also i would like to be able to change color of status bar from purple to another color.
Is that a typo?After updating Alldup to version 4.6.72
Should it read 4.5.72 ?
Sry my bad made mistake but what i was saying is that newest version won't select files in one folder along with other subfolders inside it when i was comparing two folders for duplicatestherube wrote: 13 Jan 2026, 00:01Is that a typo?After updating Alldup to version 4.6.72
