Creating a list of checksums
lilgos
Post by lilgos »
Is there a way to download a list of checksums from the database? Or when you start a search is there a way to have the checksum appear alongside the other data? I am intending to do checksum validation with our files every couple of months, and that requires a stable list of checksums to compare against.
Re: Creating a list of checksums
Try this app: Checksum Compare
checksum.adb is an sqlite file.
So see what you might be able to do with that.
SQLite, from command line or I imagine there are any number of GUI's out there.
Some rambling on "hashing".
voidhash
voidhash, the ramble
(And that said, I've not found anything that I'm truly comfortable with, not command-line, not GUI.)
