The search was aborted because Windows cannot allocate any more memory for the search.
Shooter3k
Post by Shooter3k »
I can't quite seem to get this comparison to run without failing due to memory issues. What sort of options do I have?
I'm using Windows 10 with 128GB of ram
3/25/2024 12:56:31 PM - AllDup 4.5.60
3/25/2024 12:56:31 PM - Search method: File name + File content
3/25/2024 12:56:31 PM - Comparison method: Compare all characters of a file name
3/25/2024 12:56:31 PM - Comparison method: MD5 (128-Bit)
3/25/2024 12:56:31 PM - Option: Use database
3/25/2024 12:56:31 PM - 1.Source folder: Z:\f
3/25/2024 12:56:31 PM - 2.Source folder: Z:\recovered_e_Root\hashmob\hashmob_left_old\old1
3/25/2024 12:56:31 PM - Option: Compare files from all source folders
3/25/2024 12:56:31 PM - Determine file count of all source folders...
3/25/2024 12:56:38 PM - File count: 4,078,992
3/25/2024 12:56:38 PM - Scan: Z:\f
3/25/2024 1:02:20 PM - The search was aborted because Windows cannot allocate any more memory for the search.
3/25/2024 1:02:20 PM - Found 502 duplicates with a total of 412.25 KB inside folder 'Z:\f'
3/25/2024 1:02:20 PM - Scanned files: 3,550,370 / 4,078,992
3/25/2024 1:02:20 PM - Groups: 233
3/25/2024 1:02:20 PM - File comparisons: 1,154,256
3/25/2024 1:02:20 PM - Checksums created: 253,793
3/25/2024 1:02:20 PM - Database checksums stored: 253,793
3/25/2024 1:02:20 PM - Duplicates: 502 (0%) (412.25 KB)
3/25/2024 1:02:20 PM - Elapsed time: 00:05:49
Re: The search was aborted because Windows cannot allocate any more memory for the search.
Sorry, there is nothing you can do about the memory usage limit for 32-bit applications.
Shooter3k
Post by Shooter3k »
Is there any plans to upgrade this to a 64bit application?
Shooter3k wrote: 26 Mar 2024, 17:34 Is there any plans to upgrade this to a 64bit application?
No.
