AllDup Slow To Close
AllDup is Slow To Close, clicking the 'X' close button to close the program.
Takes a good 3 seconds before the UI drops off.
Win10, Ryzen 5 2600G, 8 GB RAM.
Open Alldup (4.31)
Click the 'X' to close the program
1-1000, 2-1000, 3-1000...
(GUI disappears)
Do others see similar?
(I'm not really familiar with Win10 or the machine in particular.)
On my XP machine, when I tell AllDup to close, it does so - instantly.
Edit: ... As it does on my Win7 machine.
Open Alldup (4.31)
(GUI disappears)
Re: AllDup Slow To Close
Here AllDup closes instantly using Win10 Pro x64 Version 1809 Build 17763.379 inside a VM!
Reason: more information
Odd.
Just tried a Dell Laptop.
Win10 1803 x64
i3 4030u, 6 GB RAM (so no powerhouse, but still...)
Same slowness as noted above.
Win10 1803 x64
A third computer.
Dell Inspiron desktop.
i5-6400, 12 GB, Win10 1709.
I see the same.
I MB video, .wmv, https://drive.google.com/file/d/1C6Y2Fh ... sp=sharing.
(The clicks are faint, but are there. Looks like you'll have to download it.)
(Initially open, then I click 'X' to close it [00:00:09 - 00:00:12].
Then I reopen it, & again click 'X' to close it [00:00:18 - 00:00:21].)
(I'm 0 for 3 with Win10 computers. None are mine. All are what I would think a "typical" user might be using, with no special setups, just "out of the box" systems one uses.)
I see the same.
Same delay on portable edition on i7 3770 32GB Win10 64.
At our Win10 computer it took several seconds to exit AllDup.
We found out that the cause was the Windows Defender that delayed the access to AllDup config file.
The solution was to exclude the file config4.ini in AllDup's application data folder.
These virus/malscanner slow down everything...maybe it could speed up the whole search procress if you exclude the complete application data folder.
Exclude instructions:
Go to Start > Settings > Update & Security > Windows Security > Virus & threat protection. Under Virus & threat protection settings, select Manage settings, and then under Exclusions, select Add or remove exclusions. Select Add an exclusion.
Sounds similar in concept to, Discord detecting Everything as a Game, where the file name happened to make a difference.
So maybe if instead of "config4.ini" it were named "testme.txt" (or whatever) that might subvert the issue (without have to wrangle with Defender)?
There is no -I [configuration file name, .ini] command line switch, otherwise I could test that idea with something like:
C:\> alldup.exe -I testme.txt
(to load a configuration file named, testme.txt - rather then the default config4.ini)
The next update enables the user to add certain file types to the Windows Defender exclusion list to prevent the file types being scanned by the Windows Defender.
allduperocks
Can we pass in the config file name as a command line parameter? Then we don't need to exclude INI files from Windows Defender because other INI files might actually contain a malicious payload.
Expand the combo box and exclude the AllDup directory.allduperocks wrote: 25 Jun 2024, 04:33 Can we pass in the config file name as a command line parameter? Then we don't need to exclude INI files from Windows Defender because other INI files might actually contain a malicious payload.
allduperocks
Thanks, I didn't realize you could do that.Administrator wrote: 25 Jun 2024, 11:04Expand the combo box and exclude the AllDup directory.allduperocks wrote: 25 Jun 2024, 04:33 Can we pass in the config file name as a command line parameter? Then we don't need to exclude INI files from Windows Defender because other INI files might actually contain a malicious payload.
I tried adding config4.ini, then the AllDup directory but it didn't seem to make any difference.
Why would reading a tiny config file slow down Windows Defender anyway?
Is the excluded folder the same as the AllDup's "Application data folder"? See settings at the options.allduperocks wrote: 02 Jul 2024, 05:19 I tried adding config4.ini, then the AllDup directory but it didn't seem to make any difference.
This is a question you should ask the developers of Windows Defender...allduperocks wrote: 02 Jul 2024, 05:19 Why would reading a tiny config file slow down Windows Defender anyway?
allduperocks
I excluded the top-level folder, the one that contains AllDupPortable.exe, config4.ini, and the other folders. BTW, my data folder is empty--is it supposed to be?Administrator wrote: 02 Jul 2024, 07:39Is the excluded folder the same as the AllDup's "Application data folder"? See settings at the options.allduperocks wrote: 02 Jul 2024, 05:19 I tried adding config4.ini, then the AllDup directory but it didn't seem to make any difference.
Check Options -> General -> Application data folder setting.
"We found out that the cause was the Windows Defender that delayed the access to AllDup config file."
Is this specific to alldups file access method? I use other file management software and there's little delay.
