Show Loaded Search Results Name in the Title Bar
RFE: Show a Loaded Search Results Name in the Title Bar.
So if you loaded a saved Search Results named, "Hawaii Pics",
the Title bar would show:
  • AllDup 4.5.50 - Search Result 'Find...' - Hawaii Pics
rather then (simply):
Re: Show Loaded Search Results Name in the Title Bar
The name of the loaded search result is already shown at the title bar:
AllDup 4.5.50 - Search Result 'Hawaii Pics' ...
It is (looking now)!
(I've got to go back & see if I can see what it was that I did not see - before.
[Oh, that is weird...? I'd say, "spooky", but that isn't until tomorrow.])
It is definitely there.
Only thing I can figure is...
I knowingly opened a saved Search Results.
While working in the Search Results, I must have had a question as to some of the settings used.
So knowing I already had the Search Results saved, I closed Search Results, & on returning to the main screen, it was then, that I looked & saw that the saved Search Results name was not displayed (in the title bar).
The way the program works, that makes sense, because on return, the saved Search Results list is no longer open/active (& to again see the Results, you either need to load a Saved Results list, or actually run a scan).
