Enhancement: Cannot Hide Rows eg Rows with only one file
dec
Post by dec »
i find even if close groups either just one file, i still end up pages of closed Rows: the option would be to HIDE Rows ie prob HIDE NON-open Rows
Re: Enhancement: Cannot Hide Rows eg Rows with only one file
You can use the remove command "Remove all groups with a certain number of files from the search result" to remove all groups with only one file.
dec
Post by dec »
ok. i have seen that option (somewhere :-)).
so that does that then, right?
great
thanks
dec
Post by dec »
Administrator wrote: 03 Oct 2023, 06:51 You can use the remove command "Remove all groups with a certain number of files from the search result" to remove all groups with only one file.
i eventually found that option/s.
i expected that to ebb under Groups, not under a separate drop-down - which i have never noticed before
and i see that Option only has an EXACT number of files - not greater than or less than
