i can't see this in Manual or here at a glance
specifically about renaming files after search, what placeholder/vars can be used, eg %filename%?
i only see that example and mention of environmental vars eg %user%
what other Placeholders are available eg %filename%, %size%, %created_date% etc etc?
also i see a whole page of date and time vars/placeholder. just where & how can these be used?
many thanks
don
URGENT: Placeholders & Variables
Re: URGENT: Placeholders & Variables
All available placeholders for renmaing files at the file manager are listed in AllDup's manual.
where precisely?
seeing i spent some 15-30 minutes looking
thank you for your response
1. please note that that info is under renaming files: there is no specific section on 'Placeholders' (or what i would call more correctly variables/vars or even fields), and that the word 'Placeholder' is in the table and i suspect not indexed
2. additionally, i see that those variables are a bit limited eg not file size, date created; but you are not using metatags so there are only so many vars you can have
kind regards
don
