Search Method checkboxes may be lost (unchecked), when changing Search Methods.
Set:
Search Method; Find duplicate files on the basis of their properties
Enable; File content
Perform a search
Go back to, Search Method
- at that point, File content is still enabled
Change Search Method to Find Similar Pictures
Change Search Method (back) to Find duplicate files on the basis of their properties
- at that point, no property (i.e., File content, expected in this case) is enabled
AllDup 4.5.42
Re: Search Method checkboxes may be lost
This behavior will be changed with the next update.
Comparision, bHash -> Match 93%
- switch to MD5 (& with that Match is set to 100% [as expected])
Switch back to bHash.
At this point, bHash -> Match is 100% (rather then the previously set, 93%).
(4.5.48, I've not looked at .50 yet.)
edit: (.50 behaves the same)
