Page 1 of 1
folder filter
Posted: 23 Apr 2008, 05:10
by iu
I would like AllSync to perform a 1:1 copy of files that appear in folders named "Posted" and ignore all the other folders. "Posted" folders are subfolders and are located in multiple folders. That is, \Dog\Posted & \Cat\Posted & \Bird\Posted. Is this possible?
Re: folder filter
Posted: 23 Apr 2008, 15:05
by Administrator
I think this will be possible with the following file filter text:
*\posted\*
Posted: 23 Apr 2008, 19:52
by iu
Thank you. The file filter text *\posted\* does copy only the files in the folder \Posted. However it also copies all of the other folders, although not the files within them.
Here is what I'd like to do.
Say I have the following folders:
\Dog\Posted
\Dog\Working
\Cat\Posted
\Cat\Working
I would like to end up with the following in the destination folder:
\Dog\Posted
\Cat\Posted
Using the *\posted\* filter gives me this:
\Dog\Posted (files copied)
\Dog\Working (empty)
\Cat\Posted (files copied)
\Cat\Working (empty)
which is not what I want.
Thanks!
Posted: 23 Apr 2008, 20:14
by Administrator
Please activate the folder option "Don't create any empty folders in source or destination folder".
