Shortcut manager with exit option
mtn_roadie
Post by mtn_roadie »
Allsync 2.2.20 business edition
win2k pro
I've created a shortcut with the following settings:
Run Mode: Perform Copy Operation in the background and then exit windows
Options: Display startup window for 'copy operation in background'
If you accidently click the shortcut and then click cancel in the startup window, Allsync will cancel the copy operation, but will shut down windows. If I press cancel, I would expect that everything would be cancelled and I wouldn't be forced out of windows.
Can you update this mode so the cancel button (or an alternative button is added) that will cancel the copy operation and not force you out of windows? i.e., just let you keep working.
::kindler chase::
Re: Shortcut manager with exit option
its available with the next version of allsync. thanks for your feedback!
