Page 1 of 1
Minor Bug Report
Posted: 02 Jan 2006, 03:36
by Drdul
I just discovered a minor bug in the "Other Filters" section. Using "months" for a file filter doesn't work — AllSync will not copy any files. It's a small problem that can be avoided by using "weeks" instead. If I change 1 month to 4 weeks, or change 2 months to 9 weeks, for example, everything works as it should.
Cheers!
Re: Minor Bug Report
Posted: 02 Jan 2006, 06:53
by Administrator
I have verified the age filter for files but i cannot reproduce your problem. The filter works fine with AllSync 2.7.19. Can you provide more information about your problem with the age filter?
Posted: 02 Jan 2006, 07:03
by Drdul
The version I'm using is 2.7.17, so that may make a difference.
I discovered the problem when I added a file filter to a profile to only copy files that are less than 2 weeks old. I did a copy preview and it showed me the files that would be copied. Before running it, I decided to change the filter to one month. When I did the copy preview with the filter set at one month, nothing happened. It did not show any files would be copied. I didn't realize at the time that the problem was choosing "months" instead of "weeks." Later, I changed the file filter to 4 weeks and it worked fine.
Before I figured that out, I changed another profile from 4 weeks to 2 months. When I ran a copy preview, it showed no files would be copied, and all the previously copied files would be erased! Not at all what I wanted. I changed it from 2 months to 9 weeks, and it worked fine.
It appears that when "months" is selected as a file filter, AllSync does not correctly calculate the difference between file dates and the current date. Using "weeks" avoids the problem.
Cheers!
Posted: 02 Jan 2006, 19:42
by Administrator
ok, thx, i found the problem: Internally windows "says" there is a different of 1 month if one file is from 12/2005 and the other file from 01/2006. The day of the month doesnt matter, its always a difference of 1 month, because the internal function verifies only the value of the two months.
This also concerns to week, quarters and years. The next update will use a preconfigured amount of days for the age filters "week, month, quarters and years":
week (7 days)
month (30 days)
quarter (90 days)
year (365 days)
Should i send you an update with the changes above?
Posted: 02 Jan 2006, 23:16
by Drdul
Thanks for looking into that. No need to send me an update, as I have it working with "weeks." I'll get the fix as part of the regular update cycle.
Cheers!
