Page 1 of 1
Can't select/see search results window
Posted: 21 Feb 2026, 05:47
by rickd
Hi,
I'm a new user, so I'm sorry if this question has already been answered. (I saw a similar post from 2023, but didn't see a resolution).
I'm using an up-to-date version of Windows 11 Pro.
AllDup has completed its first search.
I see the AllDup icon on my taskbar. When I mouseover it, it shows a tiny search results thumbnail with a tantalizing:
100% - AllDup 4.5.72 - Search result - 'File size + File content'
However, I can't see the actual results window:
-Clicking on the thumbnail does nothing.
-Clicking on the taskbar icon starts a second instance of AllDup, with search options, so I close it
-Alt+Tab on AllDup does nothing
I can see AllDup (32 bit) in Task Manager. Currently, it's using about 4.5% of CPU (of 14% total), 454MB of memory (of 74% total), 0 MB/s disk (of 0%), and 0 Mbps network (of 0%).
I'm hoping to find a solution, so that I won't have to abandon this search, start over, and hope for a different result.
Thanks in advance,
Rick
Re: Can't select/see search results window
Posted: 21 Feb 2026, 07:14
by Administrator
Use the tool wherzit to show the hidden AllDup search result window.
