Page 1 of 1
Select/Deselect problem
Posted: 01 Sep 2025, 16:11
by satou.kaori131
Hi, I'm a new user.
A week ago when I used AllDup, I remember being able to select some groups at a time, and when I chose select/deselect all files options, it only applied to the selected groups. But from yesterday, those options applied to all groups including the unselected ones.
Is it an error? Do I have any other option to apply to only the groups that I want?
Thank you.
Re: Select/Deselect problem
Posted: 01 Sep 2025, 19:10
by Administrator
check your setting at the search result menu bar -> "Mode"
