Cut off description text
Posted: 21 Sep 2005, 23:08
I'm running 2.7.2 version
On some of the application windows (for example on the window of a profile setup wizard) text of the copy method descriptions (explanation of what happens if methof is chosen) is cut off in the mid sentance. (check the description text of 1:1 method) I thn I saw the same problem on other dialog boxes as well, but can not be certain for sure where.
Please check it out.
