Page 1 of 1
Pictures -> Formats, no .ICO
Posted: 19 Apr 2023, 21:43
by therube
Search Method, Pictures -> Formats,
does not have a checkbox for ICO (icon) file format.
Granted, an .ico may contain 1 or more images, but you should still be able to choose that format.
(In my case, I simply renamed my files from .ico to .ico.png, & that was sufficient.)
AllDup 4.5.42
Re: Pictures -> Formats, no .ICO
Posted: 20 Apr 2023, 17:40
by Administrator
We already tested the ico format for similar pictures but because of the multi picture support of this graphics format the search results are not what we expected to get.
We will add the icon file format to the supported list for the search method "similar pictures" with the next update but dont blame us later if you not like search result...
