AllDup HELP NEEDED with File > Select, Remove DUP photos
Posted: 19 Jul 2022, 01:20
Greetings! I am new to AllDup but love that I finally found the tool I need to clean up my hard drive Pictures folder! So CHEERS to the developers and admins and people of this great forum community! Hopefully there is a simple solution to my query and someone has previously asked it and gotten an answer.
SUMMARY: Select Pictures folder, scan, get Search Result, then for EACH/EVERY group, choose ONE file to keep in each group and delete ALL the other duplicate files in that group. Repeat for all remaining groups.
Here's my confusion/frustration: After selecting my Pictures root folder and AllDup scanning it recursively, I am presented with the Search Result with the file groups. When I expand a group I can see all the details with the one Reference File highlighted in a different color. It seems that there is no easy way to KEEP the group's Reference File (since it's as good as any of the duplicates found) and remove all other duplicate files, and to repeat this process for ALL remaining groups.
Does this make sense? Through poor file management on my part, some of my Results groups have 20 or more duplicates each, making it a nightmare and very time-consuming to have to go through all those folders manually to select what to keep and what to discard as duplicates. I have 17,284 duplicates in 1,285 groups. UGH!
So if there is a way for each and every group (in turn) to AUTOMATICALLY Select the Reference File (or A specified file) to keep (UNchecked) while marking all other duplicates (checked) for removal?
I am unsure if that Reference file can be selected automatically in all groups at once, but that would solve my problem if it was a Select menu option. But if not, how do YOU choose which duplicate file in each group to keep?
Any and all help is much appreciated, so thank you in advance!
