Fixed: File Size: Cannot Tab from Size number to Format column
Posted: 28 Mar 2019, 03:13
File Size: Cannot Tab from (the second) Size number to (the second) Format column
File Filter
Exclude files by size (enable)
- also enable the second size parameter checkbox
set focus to the (first) smaller/larger then
- select either
TAB
- enter some size
TAB
- select some format
(I see... what happens at that point, if you tab, you're then focused on the format selection of the second set of sizes... but ignore that for now, & assume that the tab then took you to either the checkbox or to the second Size smaller/larger then...)
(do it the simple way)
set focus to the (second) size number block
TAB
Result:
TAB takes you back to the smaller/larger dialog,
rather then forward to the size format (bytes, kb, mb...).
File Filter
- select either
TAB
- enter some size
TAB
set focus to the (smaller) smaller/larger then
- select either
TAB
- enter some size
TAB
eh, that's weird too, so ignore all that
TAB
Result:
