Page 1 of 1
Folder Filter list order
Posted: 27 Jun 2018, 17:52
by sismeiro
Hi All,
First of all I want to say that AllDup is the definitive best duplicate file finder out there. A great thank you to the developer.
Secondly, is there an option to order the folder list in the Folder Filter? I'm almost sure that verion 3 of AllDup showed the folder list was ordered and was helpful.
Also I liked the icons on the context menu when you righ click in the files after the search that were in the AllDup version 3.
Regards,
Luis Sismeiro
Re: Folder Filter list order
Posted: 28 Jun 2018, 18:09
by Administrator
The next update enables to sort the file & folder filter lists via a clickable header.
Thx for the hint!
Posted: 02 Oct 2018, 21:30
by sismeiro
Administrator wrote:The next update enables to sort the file & folder filter lists via a clickable header.
Thx for the hint!
Hi, just to confirm that I tested with the 4.1.8 version and it worked like a charm. Thank you. :)
