I think it's a bug
Posted: 31 Mar 2018, 12:27
Hello! I really liked your application. But there is one annoying moment. The option "Ignore files with 0 bytes" does not work. I switch it, but it does not affect the behavior of the application. Zero-value files are always filtered and not considered by the application.
