Invalid: Portable: Save search results, Saves in AppData
Posted: 24 Oct 2017, 08:49
4.0.40 Portable: Save search results, Saves (name.asr4a) in %AppData%\AllDup rather then (current folder or elsewhere).
Presumably AllDup won't find Stored Search Results unless they are in %AppData%\AllDup (as in AllDup Portable won't see the .asr4a files if you move them into AllDup's "instalDir" [aka alldup.exe's directory]).
Edit:
I wonder if this isn't because I'm running 4.0."41", which mustn't be "portable".
I'll betcha...
Yes, that's it.
A combination of 4.0.40 Portable & 4.0.41 non-Portable [test] .exe yield... a little confusion until you realize
Edit:
I'll betcha...
Yes, that's it.
