Page 1 of 1
Error Running Search
Posted: 10 Mar 2017, 03:06
by kirkpat
I get this error on Windows XP: "Can't initialize the crypt system provider CryptAcquireContext2" with AllDup 4.0.18. The application works on Windows 7. Am I missing a DLL?
Re: Error Running Search
Posted: 10 Mar 2017, 09:33
by Administrator
Windows XP with Service Pack 3?
Posted: 10 Mar 2017, 13:01
by therube
Do you have the file, fldrvw90.ocx, in your instalDir\dep\ ?
Posted: 11 Mar 2017, 08:25
by kirkpat
It's either SP2 or SP3.
fldrvw90.ocx is in the dep folder.
Posted: 11 Mar 2017, 17:16
by Administrator
I runned a test with AllDup PE v4.0.18 under WinXP SP3 and the Search Method "File content SHA-1 (160-Bit)": everything runs fine...
Posted: 14 Mar 2017, 05:58
by kirkpat
Can you suggest some things for me to try to fix the problem? The error contains "CryptAcquireContext2" Should it be "CryptAcquireContext", "CryptAcquireContextA", or "CryptAcquireContextW"? Does that give a clue as to what might be wrong?
Posted: 14 Mar 2017, 08:37
by therube
Start | Run -> WINVER, should tell you the SP level, I believe.
On Win7, I "see" (& assuming what I'm looking at has any meaning), CryptAcquireContextA & CryptAcquireContextW, not '2'.
Posted: 14 Mar 2017, 10:35
by Administrator
"CryptAcquireContext2" is just a information for the developer.
Reinstall SP3. Maybe this will fix the problem.
Posted: 15 Mar 2017, 12:38
by kirkpat
I don't have the option of reinstalling the OS. Can I put the necessary DLLs in the AllDup application folder? Which DLLs do I need?
Posted: 15 Mar 2017, 12:46
by Administrator
AllDup is using the windows crypt functions and it looks like that your windows installtion is corrupted.
You need to reinstall XP or the latest service pack...
Posted: 15 Mar 2017, 17:33
by therube
If what you need is SP3,
if installing that (or reinstalling that) is enough to get you working, you can download SP3 (& this is only the SP3
update - not the "XP SP3"
operating system), you can get it from the link here,
http://www.zdnet.com/article/update-7-x ... microsoft/.
Verify the hash of your download (which is the same hash of the file I've long had on hand).
Posted: 16 Mar 2017, 10:08
by kirkpat
I can't update the OS with SP3. The only thing I can do is put the correct DLLs in the application directory if you can tell me which ones I need.
Posted: 16 Mar 2017, 13:24
by Administrator
kirkpat wrote:The only thing I can do is put the correct DLLs in the application directory if you can tell me which ones I need.
Sorry, thats not possible.
